  2. No the premier is a different keypad you will need an excel keypad
  3. Hi there, I am looking at the FI/CQR983-CO/12 I can see that it is now EOL, would you have an alternative product?
  4. Earlier
  5. I have an Excel box with a standard LCD keypad which all works fine. I want to add a second keypad and it’s from the Premier range (with key fob) but I can’t find anything that says it’s compatible . It uses the same four connections but has additional connections for two zones too. Does anybody know if the Premier keypad is compatible with the Excel box
  6. ciccio01 joined the community
  7. TXI Outdoor Curtain DetectorThe TXI is the world’s first high-mount curtain detector featuring patent-pending Triple AND Logic, delivering stable and accurate intrusion detection across the entire coverage area. Designed in a compact form, it provides reliable performance even in harsh outdoor environments, with true pet tolerance for real-world reliability. Compact Design with Advanced IntelligenceSmall in size but powerful in performance, the TXI is a discreet, high-mounted outdoor detector ideal for residential properties where appearance matters. Its sleek design blends seamlessly into building exteriors, while advanced detection technology operates in the background to ensure dependable security. Suitable for residential, commercial and outdoor applications, the TXI combines high-mount installation, curtain detection and intelligent false alarm reduction in a single compact unit. True Pet ToleranceUsing advanced volumetric sensing, the TXI accurately detects human movement while ignoring pets. This ensures reliable protection without nuisance alarms, even in active outdoor environments. Intelligent Detection PerformanceThe TXI’s patent-pending Triple AND Logic enhances detection accuracy by analysing multiple signals before triggering an alarm. This reduces false activations caused by pets, weather conditions or sunlight, ensuring consistent and dependable operation. High-Mount Curtain CoverageDesigned for flexible installation heights between 2.2 m and 4.0 m, the TXI provides stable and uniform detection across a wide range of applications. optex-TXI-datasheet-en-web.pdf
  8. Apollo Discovery Base SounderThe Discovery Base Sounder is a loop-powered, addressable sounder designed for fast and efficient installation. It connects directly to an XPERT base, delivering reliable performance with flexible tone and volume control options. Key FeaturesSimple installation using XPERT 8 or XPERT 7 base 15 selectable tone pairs to suit site requirements 7 adjustable volume levels (up to 95 dB(A) at 1m) On-site setup and testing via control panel or at the device Group, global and individual control functionality Status reporting via the fire control panel Software-defined group addressing (up to 16 groups) Built-in short circuit isolator (when used with XPERT 8 base) Unique acoustic self-test feature Flexible Installation OptionsThe Discovery Base Sounder can be: Used with an Apollo addressable detector, or Installed as a standalone unit using a base cap (sold separately): White: 45681-292 Red: 45681-293 Black: 45681-296 For full functionality, including short circuit isolation, the sounder should be installed on the XPERT 8 Base (Part No. SA5000-20X) (sold separately). Adjustable Sound OutputWith a choice of 15 evacuation tones—including the standard Apollo tone—this sounder is suitable for a wide range of applications and local compliance requirements. A secondary tone can also be configured for alerts or warnings. Volume levels can be tailored per device during commissioning. Engineers can easily adjust settings on-site using a magnetic wand and then save configurations via the control panel. ComplianceFully compliant with EMC Directive 2014/30/EU Meets requirements of the Construction Products Regulation (EU) No. 305/2011 Declarations available via the Apollo website pp5143_discovery-base-sounder_issue-1.pdf
  9. Another project. Id assume the protocol for scantronic panels would be similar
  10. Yeah, I've seen his work, I believe it's a different device, and I have got further in to the protocol than he did. Thanks for commenting though!
  11. Imsorry ive never attempted anything like that. This project may help 2 Bus interface (line driver) hardware · AndySymons/KELLY-Scantronic-994x-Keypad Wiki · GitHub
  12. A bit of a long reach this one, but I'm trying to 'emulate' a keypad for a Scantronic 8136 panel. I've got as far as identifying it using a 150bit protocol of what seems to be long and short pulses on the signal wire done through releasing the signal wire from ground and letting the panel pull it back up to +14v for a period of time 150 times synchronised by a clock. I'm hoping to build on this so that I can control my antique alarm system from my phone! Anyone have any further information on how this works, as my attempts to play back the pulses (I think) I've copied are ignored by the panel, so I'm missing something!
  13. mr0mega joined the community
  14. Ok id assume thats a power issue or cabling. Would need more info though
  15. I have no voltage on my PIR
  16. Ross joined the community
  17. This will convert the detectors single NC relay contacts to 2 sets of Form C relay connections. If tamper is required that can be wired the same or just use the tamper on the alarm panel
  18. Yes you can do this with something like Pyronix Standalone Receiver Enforcer Series Two-Way Radio [UR2-WE] - £59.06 : , Best Price Promise But id strongly recommend upgrading the control panel to a Hybrid unit to pick up the existing hard wired detectors and add your rf one
  19. Hello I'm hoping for some advice if the following is possible and if so, which products are suitable. I have an old Optima XM system with hardwired contacts for the Front Door Zone. I am trying to understand if there is a suitable product that allows me to change the hardwired door contact to a wireless battery operated contact. Is there a wireless converter I can instal next to the control box that can take the wireless signal from the contact and convert to a hardwired connection between the wireless converter and the relevant zone contacts in the Optima controller. If so, are there any suggestions of products for the converter and/or door contact. Thanks for any advice in advance.
  20. RJM joined the community
  21. zemilswift452 joined the community
  22. A lot of gear does does do that like the versigo sentry
  23. Hi everyone, I’ve been working on people counting solutions that work with most standard IP/CCTV cameras, especially for retail stores, malls, and public venues. It’s been really interesting to see how different camera placements, resolutions, and lighting conditions affect accuracy. I’ve found that keeping the camera high and angled downwards usually gives the most reliable counts, and anonymizing the footage is a must for privacy compliance. I’d love to hear how others here handle similar analytics projects. Have any of you worked on footfall or people counting setups before? Any tips or pitfalls to share? Thanks!
  24. SSDX joined the community
  25. Awesome! - All sorted now - many thanks
  26. The cp8l had 8 zones and lcd keypad. Assuming you dont want apps etc then Eaton Wired Intruder Alarm Panel Kit [I-ON10-K] - £89.38 : , Best Price Promise
  27. Hi, hopefully you can help me my Eurosec cp8l has stopped working after several years. I need to get a replacement if possible I would appreciate it if you have any suggestions for me to swop over to a new alarm thanks.
  28. what you have there is a standard contact where the installer has added the resistors they are 1K 1K ie Knight D20 5 Terminal Surface Contact [D20] - £1.14 : , Best Price Promise so you can replace the contact and re add the resistors or if you use a d75 it has jumpers to select the resistors Knight D75 Surface Contact with Selectable Resistors Knight D75 Surface Door Contact with Selectable resistors [D75MULTI] - £3.50 : , Best Price Promise
  29. Hi All We have an old ADT Accord XPC home alarm system that's been excellent. Recently we've had the alarm go off around half an house after leaving the house, then it resets itself. I've done some tests and have come to the conclusion that the problem is with our front door Reed Switch sensor. My issue is tyring to identify the door sensor I need to order - as you can see by the photos, I've taken it apart and mine has two additional resistors. Every one I've ordered so far doesn't have these resistors and wont work with my alarm system. Any help in identifying this door sensor and the replacement I need would be much appreciated. Thanks
  30. Wzwzrd joined the community
  31. Best thing to do is post photos of the transmitters and recievers The red light shows the device is activating, there will be a set of alarm contacts. these maybe C NO NC or just C and NC depending on age. This will only be on the recievers. Use a multimeter to confirm the contacts are changing states correctly
  32. Hoping for some advice and please note I am not an electrician I am just trying to troubleshoot a problem before calling one. I have two pairs of ax130 tn sensors operating lights in an outdoor domestic setting. My question is when I take the covers of the sensors what should I see as far as led lights are concerned. I have a sensor that has no light on it unless the beam is broken, it then turns red. The other sensors seem to have either a permanent red or green light on. Which is correct and can you suggest a way to troubleshoot the sensors to find out if I have a faulty one? Thank you in advance.
  33. Any panel would be suitable, the logic 6 was a double pole panel. All panels are now more complicated than the logic 6. Options include hkc, Eaton, pyronix texecom etc
  34. I have an old ADE Logic 6 wired control panel that I need to replace. It is linked to 3x wired PIRs and 3x wired door switches and I would like the replacement to have remote access via wi-fi link to my local router and suitable app. Can you suggest replacement that is not too complicated or expensive? Thanks David
  • Total Posts 7.9k
  • 27,264 Total Members
  • ciccio01 Newest Member ·
