May 23May 23 Hi AllWe have an old ADT Accord XPC home alarm system that's been excellent.Recently we've had the alarm go off around half an house after leaving the house, then it resets itself.I've done some tests and have come to the conclusion that the problem is with our front door Reed Switch sensor.My issue is tyring to identify the door sensor I need to order - as you can see by the photos, I've taken it apart and mine has two additional resistors.Every one I've ordered so far doesn't have these resistors and wont work with my alarm system.Any help in identifying this door sensor and the replacement I need would be much appreciated.Thanks
May 23May 23 what you have there is a standard contact where the installer has added the resistors they are 1K 1Kie Knight D20 5 Terminal Surface Contact [D20] - £1.14 : , Best Price Promiseso you can replace the contact and re add the resistors orif you use a d75 it has jumpers to select the resistorsKnight D75 Surface Contact with Selectable Resistors Knight D75 Surface Door Contact with Selectable resistors [D75MULTI] - £3.50 : , Best Price Promise
