  2. The customer may purchase any of these models. Then add Ajax RF transmitter. Feature / Specification WXS-RAM WXS-RDAM WXI-R WXI-RAM Detection Range 12m (180° width) 12m (180° width) 12m (180° width) 12m (180° width) Detection Type PIR (Passive Infrared) Dual-Tech (PIR + Microwave) PIR (Passive Infrared) PIR (Passive Infrared) Power Supply Battery-operated Battery-operated Battery-operated Battery-operated Anti-Masking Yes (Active IR) Yes (Active IR) No Yes (Active IR) Mounting Heights Low (0.8–1.2m) or High (2.0m) Low (0.8–1.2m) or High (2.0m) Low only (0.8–1.2m) Low only (0.8–1.2m) Design Style Bold, aesthetic face covers Bold, aesthetic face covers Minimalist, low profile Minimalist, low profile Alignment Aid Built-in spirit level Built-in spirit level Standard alignment Standard alignment
  3. We live in Spain and are looking to buy an Ajax alarm system but want to add a 180° motion detector. We do not want the curtain. We would like to buy an Optex motion detector with Ajax transmitter. Can you tell me which Optex motion detector is compatible with the Ajax transmitter please? WXI-R or WXI-RAM. Also if we were to buyan Optex detector with a different transmitter, could this transmitter be removed and we use the Ajax transmitter?
  4. SMJH joined the community
  5. I see there are several versions of the ethernet module floating about for the Honeywell panels. I have a Flex FX020 panel and the product code I can see inside the panel is C003-M-E2 v1.15 I simply want to use the GX app on my Android phone to be able to set, unset and reset the alarm remotely and also be able to enter the Engineer menus (I hold the engineer code as well as one of the user codes) IN a related question am I right in thinking that the wired RIO when used on a FX 020 has to use code 2 on the RS485 bus, my 1st and 2nd keypads currently use code 0 and 1 respectively. I should thus be able to add a 3rd keypad set to code 3? The code table in the installation manual appears to be missing a dash as it says 03 rather than 0-3 for the FX020 panel.
  6. Earlier
  7. As per our telephone conversation this morning, I can confirm payment has been received and your order is now being processed. We have been experiencing a technical error with BT, which has affected all our systems and our apologies you were not able to get in touch. This issue has now been resolved, so if you need to get back in touch all systems are now working correctly.
  8. rapidsiteservices joined the community
  9. Your phone's don't work, your emails get returned, you have a load of my money
  10. reptonsecurity changed their profile photo
  11. reptonsecurity joined the community
  12. Soley joined the community
  13. No any SAB module will need 3 wires to function 4 to comply. I dont know what you mean by
  14. Can the SDR-WEXT-00 Siren work with just using 2 wires and not use the back-up batteries? Is it possible to replace the replace the KP01 by a single hidden switch?
  15. No the premier is a different keypad you will need an excel keypad
  16. Hi there, I am looking at the FI/CQR983-CO/12 I can see that it is now EOL, would you have an alternative product?
  17. I have an Excel box with a standard LCD keypad which all works fine. I want to add a second keypad and it’s from the Premier range (with key fob) but I can’t find anything that says it’s compatible . It uses the same four connections but has additional connections for two zones too. Does anybody know if the Premier keypad is compatible with the Excel box
  18. ciccio01 joined the community
  19. TXI Outdoor Curtain DetectorThe TXI is the world’s first high-mount curtain detector featuring patent-pending Triple AND Logic, delivering stable and accurate intrusion detection across the entire coverage area. Designed in a compact form, it provides reliable performance even in harsh outdoor environments, with true pet tolerance for real-world reliability. Compact Design with Advanced IntelligenceSmall in size but powerful in performance, the TXI is a discreet, high-mounted outdoor detector ideal for residential properties where appearance matters. Its sleek design blends seamlessly into building exteriors, while advanced detection technology operates in the background to ensure dependable security. Suitable for residential, commercial and outdoor applications, the TXI combines high-mount installation, curtain detection and intelligent false alarm reduction in a single compact unit. True Pet ToleranceUsing advanced volumetric sensing, the TXI accurately detects human movement while ignoring pets. This ensures reliable protection without nuisance alarms, even in active outdoor environments. Intelligent Detection PerformanceThe TXI’s patent-pending Triple AND Logic enhances detection accuracy by analysing multiple signals before triggering an alarm. This reduces false activations caused by pets, weather conditions or sunlight, ensuring consistent and dependable operation. High-Mount Curtain CoverageDesigned for flexible installation heights between 2.2 m and 4.0 m, the TXI provides stable and uniform detection across a wide range of applications. optex-TXI-datasheet-en-web.pdf
  20. Apollo Discovery Base SounderThe Discovery Base Sounder is a loop-powered, addressable sounder designed for fast and efficient installation. It connects directly to an XPERT base, delivering reliable performance with flexible tone and volume control options. Key FeaturesSimple installation using XPERT 8 or XPERT 7 base 15 selectable tone pairs to suit site requirements 7 adjustable volume levels (up to 95 dB(A) at 1m) On-site setup and testing via control panel or at the device Group, global and individual control functionality Status reporting via the fire control panel Software-defined group addressing (up to 16 groups) Built-in short circuit isolator (when used with XPERT 8 base) Unique acoustic self-test feature Flexible Installation OptionsThe Discovery Base Sounder can be: Used with an Apollo addressable detector, or Installed as a standalone unit using a base cap (sold separately): White: 45681-292 Red: 45681-293 Black: 45681-296 For full functionality, including short circuit isolation, the sounder should be installed on the XPERT 8 Base (Part No. SA5000-20X) (sold separately). Adjustable Sound OutputWith a choice of 15 evacuation tones—including the standard Apollo tone—this sounder is suitable for a wide range of applications and local compliance requirements. A secondary tone can also be configured for alerts or warnings. Volume levels can be tailored per device during commissioning. Engineers can easily adjust settings on-site using a magnetic wand and then save configurations via the control panel. ComplianceFully compliant with EMC Directive 2014/30/EU Meets requirements of the Construction Products Regulation (EU) No. 305/2011 Declarations available via the Apollo website pp5143_discovery-base-sounder_issue-1.pdf
  21. Another project. Id assume the protocol for scantronic panels would be similar
  22. Yeah, I've seen his work, I believe it's a different device, and I have got further in to the protocol than he did. Thanks for commenting though!
  23. Imsorry ive never attempted anything like that. This project may help 2 Bus interface (line driver) hardware · AndySymons/KELLY-Scantronic-994x-Keypad Wiki · GitHub
  24. A bit of a long reach this one, but I'm trying to 'emulate' a keypad for a Scantronic 8136 panel. I've got as far as identifying it using a 150bit protocol of what seems to be long and short pulses on the signal wire done through releasing the signal wire from ground and letting the panel pull it back up to +14v for a period of time 150 times synchronised by a clock. I'm hoping to build on this so that I can control my antique alarm system from my phone! Anyone have any further information on how this works, as my attempts to play back the pulses (I think) I've copied are ignored by the panel, so I'm missing something!
  25. Ok id assume thats a power issue or cabling. Would need more info though
  26. I have no voltage on my PIR
  27. This will convert the detectors single NC relay contacts to 2 sets of Form C relay connections. If tamper is required that can be wired the same or just use the tamper on the alarm panel
  28. Yes you can do this with something like Pyronix Standalone Receiver Enforcer Series Two-Way Radio [UR2-WE] - £59.06 : , Best Price Promise But id strongly recommend upgrading the control panel to a Hybrid unit to pick up the existing hard wired detectors and add your rf one
  29. Hello I'm hoping for some advice if the following is possible and if so, which products are suitable. I have an old Optima XM system with hardwired contacts for the Front Door Zone. I am trying to understand if there is a suitable product that allows me to change the hardwired door contact to a wireless battery operated contact. Is there a wireless converter I can instal next to the control box that can take the wireless signal from the contact and convert to a hardwired connection between the wireless converter and the relevant zone contacts in the Optima controller. If so, are there any suggestions of products for the converter and/or door contact. Thanks for any advice in advance.
  30. A lot of gear does does do that like the versigo sentry
  31. Hi everyone, I’ve been working on people counting solutions that work with most standard IP/CCTV cameras, especially for retail stores, malls, and public venues. It’s been really interesting to see how different camera placements, resolutions, and lighting conditions affect accuracy. I’ve found that keeping the camera high and angled downwards usually gives the most reliable counts, and anonymizing the footage is a must for privacy compliance. I’d love to hear how others here handle similar analytics projects. Have any of you worked on footfall or people counting setups before? Any tips or pitfalls to share? Thanks!
  32. Awesome! - All sorted now - many thanks
  • Total Posts 8k
  • 27,271 Total Members
  • SMJH Newest Member ·
