[Ticket Question] ESP Aperta 1 Way Colour Video Door Entry Kit with Door Station
Just moved into house with ESP Enterview 5 and bell only sounds on the outside unit, no ring internally, so very hard to hear. Is that normal? Alternatively if I want to replace it with a newer ESP model using installed PSU what would you recommend and would the new one sound inside or do they need plugin or wired extenders?
The handsets should call when pressing the call button.
Is the handset sitting correctly when on hook as it wont call when off hook.
also the unit may have a mute facility is this enabled?
