Secware Posted February 23, 2010 Posted February 23, 2010 Dear sirs, I need to know more details about out put data format of these devices as I need to intigrate these devices with our computer control system Thanks Quote
Secware_Tech6 Posted February 25, 2010 Posted February 25, 2010 The standalone reader will only give you a volateg output on valid tag/card. The HID unit will output data. However this infomation is not in the public domain. Depending on what you want to do, you would be better off going for an access system based on ms sql and then queriing the db direct, or using a system that gives a 232 output and getting your data from their. Actually reading the data reader would be difficult IMO. James Quote
