Secware Posted February 22, 2010 Posted February 22, 2010 Hi I bought the Prox10 kit from you, and was wondering what cable should run to the keypad/lock release. It's only 12v/1amp - does it just need something like speaker cable or .5mm T&E, or is there a "proper" spec that I should use Thanks Chris Quote
Secware_Tech6 Posted February 22, 2010 Posted February 22, 2010 Chris The power requirments of the keypad itself are very low. The main value to consider is the current required by the lock. 0.5mm flex would be fine for this purpose, however is the run is short then std alarm cable is normally used. YOu may need to parralel up cores if the volt drop is too large. Quote
Secware Posted February 22, 2010 Author Posted February 22, 2010 It is a short run, so I will try it with the alarm cable first, 0.5mm second. Thanks for such a quick response - much appreciated Quote
