February 12, 201313 yr Installed an enforcer panel roughly 3 months ago and it has been working fine, setting and unsetting no false alarms etc, a few weeks ago it started flagging Mains failure, a code was entered to silence it and mains was restored. the following day it started flagging up LOW voltage on the screen, a code was entered to silence it but the orange triangle remained, the panel then died. I opened the panel and checked voltage going in and it was 240v, the battery must have ran the panel for about 14 hours but i dont see why it didnt recharge the battery because the mains was and still is entering the panel. Any suggestions or repairs i could make as its now providing no security?!
February 13, 201313 yr As the mains was off for 14 hours I would suggest that a cell in the battery may have been have been damaged, and the battery can not recharge. I would remove the battery and replace it, unless trying to recharge a damaged battery has affected the panel, eveything should be OK
February 16, 201313 yr Are you 100% certain there is power getting into the panel. Is the transformer etc ok?
