Secware Posted February 12, 2013 Share Posted February 12, 2013 Installed an enforcer panel roughly 3 months ago and it has been working fine, setting and unsetting no false alarms etc, a few weeks ago it started flagging Mains failure, a code was entered to silence it and mains was restored. the following day it started flagging up LOW voltage on the screen, a code was entered to silence it but the orange triangle remained, the panel then died. I opened the panel and checked voltage going in and it was 240v, the battery must have ran the panel for about 14 hours but i dont see why it didnt recharge the battery because the mains was and still is entering the panel. Any suggestions or repairs i could make as its now providing no security?! Quote Link to comment Share on other sites More sharing options...
accounts3 Posted February 13, 2013 Share Posted February 13, 2013 As the mains was off for 14 hours I would suggest that a cell in the battery may have been have been damaged, and the battery can not recharge. I would remove the battery and replace it, unless trying to recharge a damaged battery has affected the panel, eveything should be OK Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted February 16, 2013 Share Posted February 16, 2013 Are you 100% certain there is power getting into the panel. Is the transformer etc ok? Quote Link to comment Share on other sites More sharing options...
