Secware Posted July 4, 2012 Share Posted July 4, 2012 Hi, we are looking at the Honeywell EC01000 range of detectors. We require Optical & Ionization, can you recomend an Ionization Detector for the Honeywell Galaxy Dimension Panel and explain the diffrence in the standard and diode base. Am I right in thinking these have no sounder and if so what compatible internal sounder is available? Quote Link to comment Share on other sites More sharing options...
accounts3 Posted July 13, 2012 Share Posted July 13, 2012 You are right, there are no sounders with these detectors, the sound comes from the panel or the SAB, unless you add sounders to your system. Sounders with detectors can be found in the Fire range, but you will need to choose a fire panel to install as the voltages are different Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted August 19, 2012 Share Posted August 19, 2012 The diode bases are for fire panel use not intruder alarm panel use. Quote Link to comment Share on other sites More sharing options...
