July 25, 201115 yr Hello can anyone help,on entering the building after the alarm has been set there is no exit entry timers sounding ,and the externel bell box triggers,zone 2 which is in the path to the rkp is set as access.
July 25, 201115 yr Hello can anyone help,on entering the building after the alarm has been set there is no exit entry timers sounding ,and the externel bell box triggers,zone 2 which is in the path to the rkp is set as access. What do you have on zone 1 the entry/exit zone?
July 31, 201115 yr The magnetic contact that I assume you have fitted to your front door has 'stuck'. It needs replacing.
August 10, 201115 yr Id agree, from the info above seems your entry zone isnt starting for whatever reason.
