secware3 Posted June 6, 2025 Posted June 6, 2025 I want to specify a Paxton Pro Standalone unit for a FD60 exit door. What lock should i specify for best compatibility? Do you supply a mortice latch/lock/lever unit that works with it? Quote
Secware_Tech6 Posted June 6, 2025 Posted June 6, 2025 Yes you will need a compatible lock case to suit the door type Quote
