securitywarehouse Posted April 27, 2010 Posted April 27, 2010 I purchased a Veritas Excel panel with LCD keypad (order number 18090). On powering up the system for the first time, the keypad remains blank and does not display any text. The three LEDs on the side are lit and the keypad is illuminated and accepts key presses. Am I missing a configuration step somewhere or is the keypad/panel faulty? Quote
Secware_Tech6 Posted April 27, 2010 Posted April 27, 2010 its usually a wiring issue or cable fault. I would advise removing all wiring and the keypad from the wall and connect using a short known and tested cable. if you have followed the correct power up etc it should be fine. let us know how that goes. Quote
Casualty Posted April 28, 2010 Posted April 28, 2010 Hello, this is my ticket question from a number of weeks ago. This has been sorted with a replacement keypad. A moderator can remove or lock this thread. Thanks. Quote
Secware_Tech6 Posted April 28, 2010 Posted April 28, 2010 Thanks for the follow up. Glad its sorted. Quote
