Hi there, I have a client that requires 1-way video entry at two separate doors. The outputs of which are both required to be connected to each of two points in the building. Is this even possible and if so what kit would you recommend for it? Thanks.
if you use a conventional video system then yes. All you need to do is feed the 2nd monitor from the first unit, ie cable it as below
Outside Unit ------ HAndset 1------- Handset 2
