Secware2 Posted April 8, 2020 Posted April 8, 2020 All has been fine then about a month ago while setting it l received the message open zone 5 l don't know what have caused this. Have you any ideas? That zone is on a PIR Its a Honeywell lS3012.If you think l need to purchase a new PIR let me know or could it just need re programming? Quote
Secware_Tech6 Posted April 8, 2020 Posted April 8, 2020 You will need to diagnose the issue, it could be a bad connection, failed pir or cable damage etc. What control panel do you have, maybe you could upload a picture of the panel connections?> Quote
Darrenw Posted April 8, 2020 Posted April 8, 2020 Hi thanks for the quick response. I have attached a couple of pics to help. Nothing has changed since l installed it exactly 1 year ago. It has been working completely fine. So l'm hoping to rule out cable damage. Scantronic 9651 Quote
Secware_Tech6 Posted April 8, 2020 Posted April 8, 2020 ok thanks If you connect the circuit wires together (the alarm pair) in the pir (put them in the same connection in the pir ie NC, then close detector and test that will prove the wire and the panel is ok. Let us know how that test goes? Quote
Darrenw Posted April 9, 2020 Posted April 9, 2020 Also after l sent you these pics l came out of installer mode and these are the messages on the keypad first no faults when l put the control panel lid back on then went to set the alarm and received the open zone message. Although the PIR sensor led is working normally the paneldoes not pick up the sensor on a walk test. This morning l have done what you asked and sent a pic. When l closed the PIR and tried to set the alarm it said zones 5 and six are open and although led's are working on both zones neither are picking up on a walk test. Hope this helps Regards Darren Quote
Secware_Tech6 Posted April 9, 2020 Posted April 9, 2020 ok next we need to loop out circuit 5 and 6 at the panel. Just take a small loop of wire across each circuit Quote
Darrenw Posted April 9, 2020 Posted April 9, 2020 Okay, done that and a bit of progress, its now letting me set the alarm. What next? Regards Darren Quote
Secware_Tech6 Posted April 9, 2020 Posted April 9, 2020 it looks like you have a cable failure on your alarm pair. You can confirm with a meter. As you shorted them in the detector and it still showed as open rules out the detector. Linking out the panel rules out the panel at fault. All that is left is the cable. Quote
Darrenw Posted April 9, 2020 Posted April 9, 2020 Oh, not the news l wanted. But really appreciate your help. I have a multi meter. Can you help me to check the cable's please? Quote
Darrenw Posted April 9, 2020 Posted April 9, 2020 OMG Sorry forget the last couple of messages from me. On closer inspection l realised l had one of the tamper and one of the circuit cables round the wrong way on 2 zones. I have now put them the right way round weirdly the alarm was working fine. However l have done what you asked me to do last night and now the alarm will set (connecting the circuit wires together in PIR) I have also checked all the wires in the panel with a meter and none are damaged. I have also swapped the fronts of the PIR's and still have the same results. So do you think its the back section of the PIR? Sorry to bother you again Regards Darren Quote
Secware_Tech6 Posted April 10, 2020 Posted April 10, 2020 OK sorry if you have mixed up wires the test didn't prove anything. So I'm clear if you link the wires in the detector then you can arm the system? Quote
Darrenw Posted April 10, 2020 Posted April 10, 2020 Yes. I linked the correct wires in the detector and it closed the zone. So this morning l have swapped the back of the PIR in another room and wired all as per normal and amazingly it all appears to be working. I've tested it a couple of times. (Sure the neighbour's are pleased) but there is no way l could have done that without your help. The only thing l don't understand is how it had worked for the last ten months. Anyway is there anywhere l can rate or review your help? Much appreciated Regards Darren Quote
Secware_Tech6 Posted April 10, 2020 Posted April 10, 2020 Anytime I can only assume it was a bad connection and now with moving it that termination is correct now Quote
