Secware Posted July 3, 2019 Share Posted July 3, 2019 Do the Honeywell sensors, external siren and tag reader with built-in siren communicate over encrypted rolling code? Do these - FG8M, DFS8M, CO8M, IR8M, IRPI8M, DO8M, SEF8M and SPR-S8EZ, etc. I know the fobs and panic buttons do. These do - TCC800M, TCPA1B, etc. I am using the Honeywell Evohome Security at the moment, that uses the Le Sucre+ box. Is the Le Sucre+ box and the SPR-S8EZ grade 2 EN50131, if they are not grade 2 EN50131 is the dominion a better control panel to use instead? I know the sensors, external siren, fobs and panic buttons are grade 2 EN50131. Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted July 3, 2019 Share Posted July 3, 2019 The higher the grade the higher the security level. If you don't need wireless bells I'd look at the galaxy with portal Quote Link to comment Share on other sites More sharing options...
Secware Posted July 3, 2019 Author Share Posted July 3, 2019 Edited questions - Do the Honeywell sensors, external siren and tag reader with built-in siren communicate over encrypted rolling code? Do these - FG8M, DFS8M, CO8M, IR8M, IRPI8M, DO8M, SEF8M, SPR-S8EZ and GKP-S8M, etc. I know the fobs, panic buttons and maybe external siren communicate over encrypted rolling code. These do - TCC800M, TCPA1B and I think this does SEF8M , etc. I am using the Honeywell Evohome Security GPRS model at the moment, that uses the Le Sucre box+. Is the Le Sucre box+, the SPR-S8EZ and the GKP-S8M grade 2 EN50131? As if they are not grade 2 EN50131 is the dominion a better control panel to use instead, as that is grade 2 EN50131? I know the sensors, external siren, fobs and panic buttons I have are grade 2 EN50131. Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted July 3, 2019 Share Posted July 3, 2019 No it is not grade 2 Quote Link to comment Share on other sites More sharing options...
Secware2 Posted July 4, 2019 Share Posted July 4, 2019 *Forget my previous 2 posts, as I made mistakes by leaving parts out, so please use my wording below instead, please answer my question about do they** communicate over encrypted rolling code.* Edited questions - Do the Honeywell sensors, external siren and tag reader with built-in siren communicate over encrypted rolling code? Do these - FG8M, DFS8M, CO8M, IR8M, IRPI8M, DO8M, SEF8M, SPR-S8EZ and GKP-S8M, etc. I know the fobs, panic buttons and maybe external siren communicate over encrypted rolling code. These do - TCC800M, TCPA1B and I think this does SEF8M , etc. I am using the Honeywell Evohome Security GPRS model at the moment, that uses the Le Sucre box+. Is the GKP-S8M, which is for the Dominial grade 2 EN50131? As is the Dominial a better control panel to use instead, as that is grade 2 EN50131? I need to have grade 2 EN50131, as I know that is the highest grade for wireless and I need it to be wireless. I know the sensors, external siren, fobs and panic buttons I have are grade 2 EN50131. Quote Link to comment Share on other sites More sharing options...
Secware2 Posted July 23, 2019 Share Posted July 23, 2019 We had forwarded your query onto Hneywell for them to assist, however sadly having not received an answer have received the below to our chase: Concerning your query about Grade 2 RF Products. Your e-mail had been forwarded to another department for further handling but I have understood that you have not received an answer yet – our apologies for that. Resideo support can be contacted directly via the following telephone number: (+44) 0800 279 3643. They should be able to provide you with an answer. Quote Link to comment Share on other sites More sharing options...
