as118150 Posted December 17, 2009 Posted December 17, 2009 good morning. can anyone please help me in picking an internal sounder which can work with cpx? thanks Quote
Secware Posted December 17, 2009 Posted December 17, 2009 Good morning You can use any make of sounder/speaker with the CPX panel, you have a wide range of makes CQR, Pyronix, Secware and to be fair they all tend to be as good as one another Hope this helps you Regards Elaine Quote
as118150 Posted December 17, 2009 Author Posted December 17, 2009 elaine, my control panel will be in the garage and keypad in the hall, would the beeps come from the keypad when I enter and exit after arming or do you need the sounder for this beeps? thanks Quote
Secware_Tech6 Posted December 19, 2009 Posted December 19, 2009 The keypad will also emit entry exit sounds, but obviosly at a lower volume. The Eurosec comes with a small extension speaker that can be mounted seperate to the panel. Quote
