Secware Posted August 9, 2016 Posted August 9, 2016 i have bought Jablatron Freewave 4 Button wireless keyfob - white (RC-86-W) to replace old ones however when I try to programme them they are not working ?can you give any help on this matter? Quote
Secware Posted August 16, 2016 Author Posted August 16, 2016 what do you mean Have you got the right frequency how would I know this ??I bought same model as I had before ? Quote
Secware_Tech6 Posted August 16, 2016 Posted August 16, 2016 Have you deleted the old ones I could use a bit more detail on what you have done so far to programme them Quote
Secware Posted August 16, 2016 Author Posted August 16, 2016 I have followed the data sheet1. Press and hold . The keyfob flashesonce and after a while starts to lightcontinuously.2. Keep pressed while pressing xtimesaccording to the table below.3. Then release to end configurationmode.4. As confirmation, the LED flashes thesame number of times as you pressedthe button.The default mode is 5: No lock - unlockpossible, no one-button PANIC possible,both pairs are 868MHzBattery replacement Quote
