November 9, 200916 yr What is the difference between the Texecom Veritas R8+ and the Veritas Excel??? According to the comparison chart there doesnt seem to be a difference in hardware? Is there a difference in software? If so what are these differences? Once again securitywarehouse* are the CHEAPEST by 68p with their competitors triton direct! Id use securitywarehouse though as you have good service!
November 10, 200916 yr Ravi Id have to check the tech docs but from memory the excel has remote pc options and eol options. It used to be the excel was the lcd version. If you want me to have a good look re specs let me know. Also re the price. We should be cheaper as well as better value, are you saying we arnt? James
November 10, 200916 yr Author see the R8+ I had before it went faulty had eol and the pc upload/download...? You are the cheapest too lol I wasnt being sarcastic!!! I couldnt seeany difference atall, they both even look identical.
December 6, 200916 yr Author The R8+ allows the use of LCD keypads. Is the difference that the R8+just comes with a standard LED keypad and the excel comes with an LCD keypad?
December 7, 200916 yr Hi Ravis, The Key features of both panels are Both have 8 zones both have EOL zone configuration both will take 6 remotes both will take LED/LCD both have communicator interface both have 250 event log and the only difference is R8 plus comes with a LED and the Excel comes with a LCD keypad Hope this helps you with your query Regards Elaine
