I recently purchased a Honeywell galaxy G2K3WR-01-C and ADE Honeywell 8IR103 PIR.
I require some technical support for wiring the Activ8 detector (ADE Honeywell 8IR103 PIR).
I have the usual manual which comes with the panel and the detector but it is not that clear.
I am simply putting one detector per zone and resistors at the detector end.
I which to know where the resistors are actually connected to and where cables are connected to. Would you be able to assist please?
Also, can you advise what speech dialler would I need for this system please ?
zone wire going out goes to tamper in,
zone wire returning connects to relay out
2 resistors connected in series inbetween
Usual connections for +/- V
