November 6, 200916 yr I was dissapointed to find the Bosch blueline range were not suitable for outdoor use as I have request for a backdoor light in a rural environment where bats birds and badgers roam freely. Does anyone know of an equivalent product product without getting into expensive wireless systems? The other problem is that I would need either two of these units or one that would have a wide enough angle to operate on a corner
November 6, 200916 yr You are right the Bosch units are for internal intruder alarms, you will have to have a look at the GJD or Voltek sensors for external use Regards Anne
November 7, 200916 yr There are hard wired external PIR's that are suited to pet tolerant situations. eg Optex VX402 The Takex External Pet PIR and the risco watchout. Tech Support
November 12, 200916 yr Hi Sorry the powermax does not have the compatible outputs needed, so you would not be able to fit the Optex VX042R detectors in this instance Anne
November 12, 200916 yr Well Yes and no The 402R is a low voltage sensor with space for a seperate radio transmitter So as it comes the answer is no. But if you add a universal transmitter to it (to suit the reciever) then yes. Tech Support
