Secware Posted October 6, 2015 Share Posted October 6, 2015 I have purchased a Menvier M12 4 in 1 Smoke detector and now need to try and change the head of it to just a heat and not smoke sensor, as it is located in the kitchen. Please can you let me know if you sell in the same style and size a heat only sensor and if it is possible to simply change the head from the one detailed above to a heat sensor one? If Menvier do not make a heat sensor in this style, do you have one from another supplier which would screw onto my existing Menvier smoke detector body which is already wired in? Thank you Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted October 8, 2015 Share Posted October 8, 2015 Just change the dip switches on the head. Quote Link to comment Share on other sites More sharing options...
