July 6, 201511 yr Dear.I try to install KP-250 PG2 to my Powermaster 30. But the cetral unit only say: "Wrong ID". What shall I do?
July 15, 201511 yr I have tried both the automatic enroll procedure and enter the number manually. Nothing worked.
August 3, 201511 yr On the unit there should be a ref "868-1:**" 1 denotes UK, 0 European, as UK panels and peripherals are not compatible with European models.
August 10, 201511 yr Dear. The ref. no. is "868-1*". All units (including panel and KP-250) is bought from you.
August 13, 201511 yr Please use our ticket support system, and advise the order number so that we can look into this for you.
