Secware Posted July 6, 2015 Posted July 6, 2015 Dear.I try to install KP-250 PG2 to my Powermaster 30. But the cetral unit only say: "Wrong ID". What shall I do? Quote
Secware_Tech6 Posted July 7, 2015 Posted July 7, 2015 Have you followed the rf enroll procedure fully? Quote
Rexmer Posted July 15, 2015 Posted July 15, 2015 I have tried both the automatic enroll procedure and enter the number manually. Nothing worked. Quote
Secware2 Posted August 3, 2015 Posted August 3, 2015 On the unit there should be a ref "868-1:**" 1 denotes UK, 0 European, as UK panels and peripherals are not compatible with European models. Quote
Rexmer Posted August 10, 2015 Posted August 10, 2015 Dear. The ref. no. is "868-1*". All units (including panel and KP-250) is bought from you. Quote
Secware2 Posted August 13, 2015 Posted August 13, 2015 Please use our ticket support system, and advise the order number so that we can look into this for you. Quote
