Secware Posted March 25, 2015 Posted March 25, 2015 I am considering buying some honeywell equipment to upgrade my alarm to wireless. Firstly I just wanted to check that all the components are fully compatible with the Galaxy G2 panel (I have the G2-20, or actually the G2-12 as it is not expanded), and that it will support this many sensors. Do you know this for sure, or should I contact Honeywell directly Honeywell Wireless Door/window compact magnetic contact Honeywell Wireless Dualtec 15m x 18m Honeywell Wireless Smoke sensor with built-in sounder DF8M Honeywell Carbon Monoxide Wireless Detector Honeywell Galaxy 2 Series Wireless Receiver (RF Portal) Microtech Galaxy MK8 Keyprox LCD Keypad Honeywell Galaxy Four-button compact two-way keyfob Quote
Secware_Tech6 Posted March 27, 2015 Posted March 27, 2015 Yes but if you have a 2-12 you will probably not have enough circuits available Quote
fumet Posted March 28, 2015 Posted March 28, 2015 Hi, Thanks for your response. I thought number of zones may be an issue. My current shopping list is as follows :- Honeywell C079-2 RF Portal Honeywell CP051-00-01 MK8 keyprox Honeywell C072 Boxed RIO expander 3x Honeywell TCC8M wireless keyfob Honeywell SMB10 Motion sensor mounts RS485 Bus wire : Twisted pair screen cable Belden 8723 equivalent 680 Ohm resistors 4x Honeywell DO8M - Door 5x Honeywell IRPI8M - IR 6x Honeywell DF8M - Smoke 2x Honeywell CO8M - Carbon Monoxide So I have 17 Wireless sensors. My understanding is that if I connect the C072 Boxed RIO, that will give me the total of 20 wireless zones - which are just used for sensors. I swapped the Dualtec IR sensors in my original list for an older model as they apparantly require G2 firmware to be at v1.50 and over. My firmware is at v1.42 and I don't want to get into firmware flashing. All the information that I could find suggested that everything in the above list is compatible with my firmware. Is this a sensible list? Will it all work together? Hope you can help, and thanks again..... Quote
Secware_Tech6 Posted March 28, 2015 Posted March 28, 2015 If you have a g2-12 no. If you have a g2-20 yes. But the number after the 2 (ie 12,20 or 44) denotes max circuits Quote
fumet Posted April 1, 2015 Posted April 1, 2015 Hi, From my understanding, I have a G2-20 which only allows 12 zones out of the box (as does the G2-44). You have to use a RIO expander box on the RS485 bus to get up to 20 zones on the G2-20 and up to 44 on the G2-44. Is this right? I referred to my unit as the G2-12 as I have seen it referred to as that online - but I think that naming is misleading/wrong. Am I on the right track or am I still confused?! Thanks! Quote
fumet Posted April 1, 2015 Posted April 1, 2015 Hi again. I did find G2-12 kits separate from the G2-20 kits from Honeywell so I guess I was wrong in my assumption? I cannot find an online installation manual for the G2-12 though, do you know where I can find one? Thanks again! Quote
Secware_Tech6 Posted April 10, 2015 Posted April 10, 2015 If you add the portal you can use the circuits. You only need a Rio for hard wired. You can use upto 20 circuits of either type in total Quote
