October 21, 201411 yr I would like to know if I can use a GJD sapphire mk3 control box with a Takex PB 30 TK . Both are 12volt is it compatible
October 22, 201411 yr Can you not use a GJD detector the GJD 940 is their standard beam. You could use the Takex but it would then work 24 hours as there is no way for the Takex beam to know the difference between day and night
October 23, 201411 yr It could be done but as above will not work on its own perfectly. Might be better to say what your trying to achieve?
