MAG2P
esp fireline MAG2P, is that for surface mounting or for flush mounting into a cut plasterboard wall?
  • Author
thanks, i ordered the poly version of the MAG4P and received the metal one the MAG4. have emailed for an return and replacement ???
  • Author
cheers, also the esp fireline sensor combined heat detector/optical sensor listed on your site is in fact a rate of heat rise/optical sensor, i think your graphic diagram on that pge needs updating as the model number is different to the diagram. i ive emailed for an RMA ???
  • Author
hiya, have tried contacting for a returns RMA via email but havent heard back. should i just return for a full refund without an RMA? ive reordered under a different order. the original order was number # 12844 and i then reordered under # 12988 and bank transferred the money yesterday for that for new sensors and a plastic panel. i am returning 5 of the incorrectly supplied CSD-2(listed as CSD1 on invoice and on website diagram and description) , 4 of the FHD-1,and the incorrectly supplied metal panel many thanks again for your help.
  • 1 month later...
