Secware Posted July 30, 2012 Posted July 30, 2012 I am after a remote that will work on a Sterling 10 for setting/unsetting? Is this possible? Quote
Secware Posted July 30, 2012 Author Posted July 30, 2012 On the Sterling 10 there are outputs that can be programmed as "keyswitch" that can be connected to certain external equipment that can arm and disarm. Pyronix produce a Prox SA that is a stand alone tag reader that connects to the Sterling and can be used to arm and disarm via presenting a tag: http://www.securitywarehouse.co.uk/catalog/pyronix-stand-alone-tag-reader-used-for-armingdisarming-system-p-3236.html Quote
Secware_Tech6 Posted August 19, 2012 Posted August 19, 2012 However whilst this is possible i would recommend a panel with prox integrated. As shorting the wires in the above procedure could disable the alarm. Quote
