Secware Posted June 11, 2012 Posted June 11, 2012 I wish to set up a perimeter system to my property consisting of 3 sets of takex external 4 beam. I was wondering which transmitters and receivers (GSM) you recommend for such, and also if there are any security lights that could be triggers by breaking the beams, Quote
Secware_Tech6 Posted August 19, 2012 Posted August 19, 2012 The detectors are that, just detectors. You can wire them into anything with suuitable inputs etc. I would advise using a control panel to run the system and wire the beams into that. The panel type id recommend would depend on faetures required. If just basic on off etc the id say a honeywell optima. This will also power your beams. Then wire a relay from the bell output of the panel to trigger the lights. You can then connect a gsm dialler or normal dialler to the bell trigger, or use an accenta to get dedicated trigger outputs. Quote
