Secware Posted February 13, 2012 Share Posted February 13, 2012 full Texecom Veritas Excel alarm system After a busy couple of weeks I finally got to installing it this morning. I didn't wire the end station to my field devices just yet, I just linked one of the remote keypads to program my own user codes in. Following the manual, I powered with the battery first and the panel powered up for around 30 seconds but then switched back off (I had just disarmed the panel with the default code and was about to enter the programming menu). I tried powering up again but the panel didn't switch on. I then disconnected the keypad and tried it again with battery and then on mains, nothing happened. No LEDs or anything... The battery is a 2.3A/h and is compatible as far as the manual states? I am quite confused as to what has happened as I have followed all proceedings by the book, literally. I checked all wiring repeatedly and there wasn't a problem with it. I checked the manual and it advised to change the fuses on the board; only there are no fuses. I changed the mains fuse but that made no difference. Can somebody advise if there is something I can do to get the panel up and running again or swap it out if it is a faulty unit? Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted February 13, 2012 Share Posted February 13, 2012 id suggest you have blown a fuse. DO you have 12v at all power outputs. Check the keypad power first? Quote Link to comment Share on other sites More sharing options...
ravis94 Posted February 13, 2012 Share Posted February 13, 2012 Deleted Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted February 16, 2012 Share Posted February 16, 2012 ok glad youve got it sorted Quote Link to comment Share on other sites More sharing options...
