Secware Posted February 2, 2012 Posted February 2, 2012 As requested please follow links below to the 4 zone fire panels currently available online: http://www.securitywarehouse.co.uk/catalog/esp-fireline-4-zone-fire-panel-poly-p-1487.html http://www.securitywarehouse.co.uk/catalog/ctec-cfp7044-4-zone-conventional-fire-panel-p-1301.html http://www.securitywarehouse.co.uk/catalog/ctec-cfp704e4-economy-4-zone-conventional-fire-panel-p-1304.html http://www.securitywarehouse.co.uk/catalog/fike-4-zone-twinflex-plus-control-panel-p-1312.html regarding the 2 outputs please descibe what the outputs would be for, to be able to help further? Quote
Secware Posted February 2, 2012 Author Posted February 2, 2012 I need 2 outputs on the Fire Alarm because there is currently a door on an lectric release on the only output that is available on their current firealarm. I need the second output for another door that we have installed an electric release and keypad entry onto. Quote
Secware Posted February 2, 2012 Author Posted February 2, 2012 Use any 4 zone panel and then use 2 fire relays for your two outputs. I can recommend Cranford: http://www.securitywarehouse.co.uk/catalog/cc-r24box-p-242.html Quote
Secware_Tech6 Posted February 2, 2012 Posted February 2, 2012 As above wire the single fire output to 2 external relays. Then use each relay for the desired purpose. Quote
