Having a problem with the new units : Initially both TX units were recognized by the RX unit and worked correctly but after about 15 minutes one of the TX units ceased to be recognized (the PIR is working since the LED flashes on the TX unit but the RX unit is not responding).
Have disconnected and reconnected power to both TX and RX unit and used RX program mode to attempt to re-detect TX unit but still no response.
Is there any other "reset" procedure or is the TX unit faulty?
  • 4 weeks later...
