Secware Posted August 9, 2011 Posted August 9, 2011 I have a Racalite Light control system running 4 external lights via 4 sensor heads. The sensor heads are the type supplied with a Guardall Excalibur system. I am looking to obtain 2 replacement sensors capable of operating on the current system. Specification of current sensor heads is: Power: 10-16v dc Temp range: -20 to +55C Steering Adj: +/-90deg horizontal +10 to -50deg vertical IP rating: IP55 Detection range: 17m 100deg field of view. Can you supply 2 suitable sensor heads? If so how much? Quote
Secware_Tech6 Posted August 10, 2011 Posted August 10, 2011 there isnt a head directly compatible but the voltek and/or the gjd units will definetly work with a little work. Do any of your existing heads still function. I need to know how they switch on their signal wire, then i can tell you how to wire in another brand. But voltek/gjd switchers are not dear might be simpler to replace the switcher too. Quote
