It depends what type of system you are planning to put it on...
Addressable or conventional?
The only sensor with integrated sounder and strobe is the Gent S-Quad. I use them in my house only mine have the voice sounder with strobe. That sensor only works with with the Gent vigilon or Nano.
There's also the Rafiki ASD sensor that had the option of a strobe but it needs a special panel also...
If it is for a conventional system you will need to buy a multi sensor and a sounder beacon base. This will need a zone pair and a sounder circuit pair of cables going back to the panel.
