September 13, 201016 yr Hello Guys, Where can I buy Magnetic Strips to fit across window/glass.This is for business premises. Or is there other convienient solution.Obviously this works with Tamper circuit. Your help would greatly appriciated. Thanks. Freddy
September 13, 201016 yr These strips as you call them are quite old technology now, they deteriorate with moisture that tends to be on windows in the back end of the year, and are very labour intentsive, so most installers tend to prefer to use glass break sensors.
September 13, 201016 yr Author Thanks for the quick response. I will fit the Glass break sensors. Thanks again.
September 23, 201016 yr as above i assume you mean window foil. Still an excellent system as long as its not misused. very expensive to impliment and only suitable on certain glass types.
