kaibil Posted September 13, 2010 Posted September 13, 2010 Hello Guys, Where can I buy Magnetic Strips to fit across window/glass.This is for business premises. Or is there other convienient solution.Obviously this works with Tamper circuit. Your help would greatly appriciated. Thanks. Freddy Quote
accounts3 Posted September 13, 2010 Posted September 13, 2010 These strips as you call them are quite old technology now, they deteriorate with moisture that tends to be on windows in the back end of the year, and are very labour intentsive, so most installers tend to prefer to use glass break sensors. Quote
kaibil Posted September 13, 2010 Author Posted September 13, 2010 Thanks for the quick response. I will fit the Glass break sensors. Thanks again. Quote
Secware_Tech6 Posted September 23, 2010 Posted September 23, 2010 as above i assume you mean window foil. Still an excellent system as long as its not misused. very expensive to impliment and only suitable on certain glass types. Quote
