September 9, 201016 yr We have a scantronic 9448 alarm system and have recently had a new front door fitted. The original door was solid wood and had a door sensor fitted into the top of the door. Our new door is upvc and we require a flush fitting sensor which can be connected to the existing wiring. Please advise on which item we should select.
September 23, 201016 yr have a look here http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=667
