September 8, 201016 yr Hi - I have a Scantronic 500r+ wireless alarm system - and need to add a new movement detector sensor to the system for our kithen. Ive looked on your website and there seem to be a number of different movement detectors that go with Scantronic wireless systems - so wondered if you could advise which one would be best to add to out system. Our present detectors are all square-ish - and there are a couple that look similar - but could you pl let me have a model no I should order? Could you either pl email me or leave a message on the above mobile. Thanks.
September 8, 201016 yr It is really a matter of opinion, what you like the look of, you could look at the Quest or IS215 unless the position you are thinking of fitting the detector needs a Dual Tech, or other harsh/pet enviroment detector
September 8, 201016 yr Author Thanks for your reply. Would the scantronic 520r sensor work with our current scantronic 500r plus alarm system (at
September 13, 201016 yr Author Although the IS215T & Quest are popular sensors they would not be compatible with the Scantronic 500+ control panel. However, the Scantronic 520r would be compatible.
September 23, 201016 yr CHeck the freq of your current sensors. Other than that they should be compatible
