September 7Sep 7 I need to replace a PIR motion detector for my home alarm system. The sensor that needs replaced has 7 terminals at the top of the circuit board. They are:12v power +/-, Alarm NC x2, Test x1, Tamper NC x2. Do you sell a detector with the same connections? I tried a Pyronix MeQBlue but it only has 6 terminals (no Test terminal) and also the terminals are at the bottom of the board and not the top ( the cable length and positioning are quite limited). Thanks for your help!
September 7Sep 7 the test terminal is usually only requred on a grade 3 system? What sensor do you currently have a photo of the sensor will help us identify it
