secware3 Posted July 15, 2025 Posted July 15, 2025 Hi how do I omit a zone on key a control pad 9651 /9941? Quote
Secware_Tech6 Posted July 15, 2025 Posted July 15, 2025 Omitting Zones Your system may be programmed so that you can omit individual detectors. Ask your Installer which zones can be omitted. To omit a zone: 1. Key in your access code or present a tag and press X. The display shows: Omit Zone? 2. Press the number of the zone you want to omit (for example, key in 07 to omit zone 7). 3. Press Y. The sounder gives a double beep and the display shows the zone number followed by an "o": Note: Omit Zone? Omit Zone 07o If the display shows a “x” after the zone number then you cannot omit that zone. To omit further zones repeat steps 2 and 3. 4. Press X to finish. To set the system with an omitted zone: 5. Key in your access code (or present a tag) and press a Level key.. 6. The control unit gives an error tone and the display shows (for example): A:Omit Zone 07? 7. Press Y. If necessary, press Y again for each omitted zone shown on the display. (If you wish to escape press X.) After you press Y for the final omitted zone the control unit starts to set. Quote
