secware3 Posted 8 hours ago Author Posted 8 hours ago Unfortunately we cannot confirm this, as it has not been tested by us. There are many telephone adapters and routers themselves, that can simulate PSTN lines, however , there is no guarantee our PSTN products, including the SD1+, will function correctly, as they were never designed to work on this type of arrangement/digital line. You should also be aware that the SD1+ is obsolete and have been replaced by the SD-LTE; Eaton Universal 4G speech dialler [SD-LTE] - £240.00 : | Best Price Promise | Security Warehouse Professional products Kind Regards, Security Warehouse Technical Support Quote
Secware_Tech6 Posted 3 hours ago Posted 3 hours ago As above converters are not designed or tested for this purpose. It may work 80% of the time but may not when actually needed. You need a communicator designed for ip or gsm Quote
