secware3 Posted 8 hours ago Posted 8 hours ago Having some frenchdoors replaced but the old sensor broke so can this sensor also be wired to my existing alarm system Veritas system Aritech GS612 Shock Sensor https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/misc-detectors-c-36_84/aritech-gs612-shock-sensor-p-3509.html Quote
Secware_Tech6 Posted 2 hours ago Posted 2 hours ago The aritech se sirs require either a compatible panel or an analyser. You may be better off with a knight combined unit Quote
