secware3 Posted June 2, 2025 Posted June 2, 2025 Good morning I wondered if you could help, we have fitted a ali door to a business which has a Chubb alarm system, and the Chubb engineer has said the below. "The lock or keep needs to have an integral micro switch contact on it to provide electrical connections. Giving common, normally open and normally closed options for the connection onto the alarm" I could really use some help with this from someone who knows, I do have pictures of the door if i can send them across to you. Wondered if you had i stock or could get what i need, Thank you Quote
Secware_Tech6 Posted June 4, 2025 Posted June 4, 2025 what you need is a shunt lock. Different lock types are available for different doors, backsets etc Quote
