secware3 Posted May 20, 2025 Posted May 20, 2025 can you tell me if the Flex 20 Mk7 can have a lan connection plugged directly in to the unit or do i need to go through a wall port connection? Thank you https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/security-control-panels-c-36_102/1124-input-zone-medium-c-36_102_103/honeywell-flex-20-grade-2-20-zones-metal-box-mk7-p-5337.html Quote
Secware_Tech6 Posted June 4, 2025 Posted June 4, 2025 The panel will require an ethernet module and then the ethernet cable can be plugged in Quote
