securitywarehouse Posted June 28, 2010 Posted June 28, 2010 hi ive installed a 2 wire alarm system and they now have a fire shutter that they want to intergrate onto the system what would i need for this Quote
Secware_Tech6 Posted June 30, 2010 Posted June 30, 2010 You will need to take an output from the panel. What inputs doe you have to trigger the shutter, id assume the shutter is designed to be held open by the fire alarm normally. I would suggest you use the aux fire output on the panel. What panel is it? Quote
