Skip to content
View in the app
[Ticket Question] Can you recommend a simple system please?
Featured Replies
I recently purchased from you a Solitaire 4 zone controller with relevant PIR's etc. My customer then wanted a buzzer for each zone to sounder should anyone approach the property, I wired this in to complete the job.
Now he has requested a similar install for a friend of his. Having looked at the property, they simply have a front & rear to protect. Currently there is a standalone 500w pir flood to front & rear and all the customer wants is an external audible warning when someone approachs to try to deter possible burglars.
Can you suggest a simply system?
  • Author
I also believe the GJD system would be the best.
Would you recommend the 2 zone solitaire and just not connect any lights up
to it and use it for triggering the sounders?
If so are they in stock? What sounders would you use externally?
Don't worry about replying, I've spoken to GJD direct who have helped me.
I must comment on your ticket/technical service, it's not very helpful!
You can use the GJD opal and drive a sounder directly ( upto 50mA) this will give audio warning day or night , no need for lights or controller ( although you will need a 12v supply).There is usually a diagram in the packaging.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
