secware3 Posted November 1, 2024 Posted November 1, 2024 Would this battery below be a suitable replacement for a Texecom 12V 2.4AH BATTERY for an accent 8 mini alarm system? Secware 12v 2.3a/h Battery [MKES3-12SA] - £8.09 : | Best Price Promise | Security Warehouse Professional products Quote
Secware_Tech6 Posted November 1, 2024 Posted November 1, 2024 the accenta and optima mini are limited in physical size So battery choice is limited. You need to check your standby current to ensure it is suitable. The 'mini' panels wew usually used on smaller installs so the standby is usually low but it should be checked on a regular basis with a multimeter Below is as axample of the largest that will fit https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/intruder-alarm-ancillaries-c-36_46/enersys-12v-23-ah-battery-p-1339.html Quote
