secware3 Posted October 15, 2024 Posted October 15, 2024 , I have an older alarm panel that does not need EOL resistors. Is there a way to use this device without the EOL resistors selected as a normally closed circuit like traditional alarm circuits? Before I had the texecom AED 0001 which is fine but this new replacement talks about EOL resistors built in in the literature. I just want to know if it is compatible with the texecom veritas panel which doesn't use EOL Quote
secware3 Posted October 15, 2024 Author Posted October 15, 2024 Thank you for your enquiry. If this is the Impaq SC, then only the contact side (MAG)of the device will work as normally closed. The shock side (EOL) must us resistance. I hope this helps. Quote
Secware_Tech6 Posted October 17, 2024 Posted October 17, 2024 As above you will need a shock sensor that can supply cc circuits ie Knight Grade 2 Shock and Surface / Tilt Sensor [SEISMO] - £18.69 : | Best Price Promise | Security Warehouse Professional products Quote
