secware3 Posted September 20, 2024 Posted September 20, 2024 Hi, Just purchased the ACT1313 PLUS Spike suppressor. Could you advise if just the RED/BLACK/EARTH wires only need to be connected or do you also need to connect extra wires from the terminal blocks to an offending circuit. Basically not sure what the terminal block is for? As you have probably gathered I am DIYer not an alarm specialist. Any advise would be grateful Quote
Secware_Tech6 Posted September 20, 2024 Posted September 20, 2024 It's not designed for diy fitment. Nut it's a filter so what was connected to the supply should go through it. Keep on eye on load too Quote
