Eneo 4.0mm 520TVL External High res Day night camera enquiry
Eneo 4.0mm 520TVL External High res Day night camera c/w IR Leds https://www.securitywarehouse.co.uk/catalog/cctv-c-1/cameras-c-1_2/infra-red-cameras-c-1_2_86/eneo-40mm-520tvl-external-high-res-day-night-camera-cw-ir-leds-p-1955.html ---------------------
Hi, what connector does this come with please? I have an old Samsung SDE3170 system and the wires are plastered into a duct in the wall. So I am trying to upgrade my cameras without having the pull all the wires out. The camera connects to long wires with a 6 pin connector and then on the other end to the DVR with a bayonet I think its called a BNC. If this won't connect maybe you can suggest something that will. I need 4 and happy to buy a new dvf box too if it means i can reuse my wires. Thanks
From the sounds of it that sounds like some sort of kit. If its BNC at the DVR end id expect it to be the same camera end.
Do you have pictures of both ends of the cable to be sure?
