secware3 Posted June 25, 2024 Posted June 25, 2024 Need a replacement wired room sensor please. Old system runs from Scantronic 9600 keypad. Not sure what would be a sensor match for either of those in attached images. Image 5186 is of original that came with system and image 5187 is a Rokonet fitted later. Thanks. Quote
Secware_Tech6 Posted June 25, 2024 Posted June 25, 2024 id also look at the room your protecting, location etc. If its a 9600 its an old double pole panel (very old) so doesnt need reistors. Optex FlipX FLX-P-ST Flexible Range Indoor PIR Detector [FLX-P-ST] - £16.34 : | Best Price Promise | Security Warehouse Professional products Quote
